- Login to Insight Cloud Portal.
- If you have an Insight Pro account, select an organization.
- Select a location.
- Select Devices.
- Locate your Orbi Pro WiFi 6 device and on the far right select the pencil (Edit) icon.
- Select WiFi Networks.
- Locate a network to change and on the far right select the pencil (Edit) icon.
- Under Security Settings, select a security level.
The Orbi Pro WiFi 6 supports WPA3 personal security. For more information, see How does the WPA3-Personal feature improve WiFi security?.
Only WiFi devices that support WPA3 Personal can connect to the SSID when WPA3 support is included. If your wireless clients cannot connect, they need to ensure they have the latest operating systems and drivers updated on their device.
- Create a password.
- Select Save.
Your are now using the new security level.
To request product support by email, follow the link below to the Contact Us page, then:
- Click Get Support
- Click OPEN A SUPPORT CASE
- Sign in or create a NETGEAR account
- Select an eligible product to request hardware support
If you prefer to call or chat with us, select the buttons next to Email.
Contact Us
