Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
How do I set up the SSID on my Orbi Pro WiFi 6 using Insight Cloud Portal?
The Orbi Pro WiFi 6 lets you create up to four individual wireless networks on the 2.4GHz band and the 5GHz band. This feature allows network isolation between administration, employees, guests, and IoT devices. The SSID is manageable with Insight Cloud Portal. Before you set up your SSID make sure you have an Insight account. For more information, see How do I create an Insight account?.
To set up the SSID on you Orbi Pro WiFi 6:
  1. Log in to your Insight Cloud Portal.
  2. If you have an Insight Pro account, select an organization.
  3. Select a location.
  4. Select Wireless>Settings>+.
  5. Complete the appropriate fields.
  6. Select Save.
    Your SSID configurations are set.
    You can repeat this step to create more SSIDs
Last Updated:07/07/2025 | Article ID: 000062269
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
