Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Refer to the following table for a comparison of the original Meural Canvas with the new Meural Canvas II.
Canvas
Canvas II
Frame colors
  • Black
  • White
  • Dark Brown (Walnut)
  • Black
  • White
  • Light Brown (Birch)
Frame dimensions
  • 19 x 29 inches
  • 19 x 29 inches
  • 16 x 24 inches
Meural App compatibility
  • iOS
  • Android
  • iOS
  • Android
Voice control (Amazon Alexa)
Yes
Yes
Image display
  • 27-inch 1080p full HD IPS display
  • 1920 x 1080 full HD resolution
  • 300 cd/m2 brightness
Canvas II 16x24
  • 21.5-inch 1080p full HD AHVA LCD display
  • 250 cd/m2 brightness
Canvas II 19x29
  • 27-inch 1080p full HD AHVA LCD display
Orientation detection (horizontal or vertical)
Yes
Yes
Anti-glare
Yes
Yes
Ambient light sensor
  • The ambient light sensor measures the light in the room and adjusts the Canvas screen accordingly
  • Relocated to the matte board, the invisible ambient light sensor reads the same lighting as the artwork
Power consumption
29W
20W
WiFi setup
Manual WiFi setup
Rapid QR code WiFi setup
WiFi performance
  • 802.11 a/b/g/n/ac Wi-Fi (supports 2.4GHz and 5GHz)
  • WiFi 5 a/b/g/n/ac      (supports 2.4Ghz and 5Ghz)
  • Faster speeds and extended range
Port access
Located on back:
  • Micro SD card slot
  • Micro USB
  • DC Power port
Located on back:
  • DC Power port
  • Ethernet
Located behind side door for easy access:
  • SD card slot
  • Micro USB
Last Updated:07/07/2025 | Article ID: 000061262
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
