Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Change Your Orbi Pro WiFi System's Guest WiFi Network Settings in the Cloud Portal
You can set up a guest network on your Orbi Pro WiFi System, allowing guests limited access to WiFi at your location. You can change the guest network's settings in Insight. To learn more about changing the settings for an employee or admin network, see How do I change my Orbi Pro WiFi System's admin or employee WiFi network settings in the Insight Cloud Portal?.
To change your Orbi Pro's guest WiFi network's settings in the Insight Cloud Portal:
  1. Access the Insight Cloud Portal.
  2. If you are an Insight Pro user with access to more than one organization, select your organization.
  3. Select your location.
  4. At the top, click Devices.
  5. Double-click your Orbi Pro WiFi System.
  6. On the left, click WiFi Networks.
    A list of WiFi networks on the Orbi Pro WiFi System displays.
  7. Double-click the network that you want to change.
  8. To disable the network, turn the switch at the top off.
  9. To change the name, under SSID, enter a new name between 2 and 32 characters and write it down somewhere safe.
  10. To hide the network from public discovery, disable Broadcast SSID.
  11. To require users to sign in again after a certain period of time, under Time Stamp, select a time period from the drop-down menu.
  12. To require users to sign in with a password:
    1. Under Auth Option, select Password Authentication from the drop-down menu.
    2. Under Password, enter any new password between 8 and 63 text characters long. To view this password, click the eye icon.
      Write down this password somewhere safe.
  13. When you are done changing your WiFi settings, click Save.
Last Updated:07/07/2025 | Article ID: 000060320
Our team is here to help!
Phone
Chat
Email
