You can configure up to three wireless networks on your Orbi Pro WiFi System: one for administrative access, one for employee access, and one for guest access. You can change the settings for any existing network in Insight. To learn more about changing the settings for a guest network, see How do I view or change my Orbi Pro WiFi System's guest WiFi network settings in the Cloud Portal?.
Use a computer with a wired connection when you change your administrative network's network name (SSID) or other WiFi security settings. Otherwise, you will be disconnected when you click the Apply button.
To change your Orbi Pro's admin or employee WiFi network settings in the Insight Cloud Portal:
