Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Change Your Orbi Pro WiFi System's Guest WiFi Network Settings in the Insight App
You can set up a guest network on your Orbi Pro WiFi System, allowing guests limited access to WiFi at your location. To learn more about changing the settings for an employee or admin network, see How do I view or change my Orbi Pro WiFi System's admin or employee WiFi network settings in the Insight App? .
To change your Orbi Pro's guest WiFi network settings in the NETGEAR Insight app:
  1. Launch the NETGEAR Insight app.
  2. If you are an Insight Pro user with access to more than one organization, select your organization.
  3. If you set up more than one location in Insight, at the top of the page, select your location.
    The list of devices on your network displays.
  4. Tap your Orbi Pro WiFi System.
  5. Tap WiFi Networks.
    A list of WiFi networks on the Orbi Pro WiFi System appears.
  6. Tap the WiFi network that you want to change.
  7. To disable the network, turn the switch at the top off.
  8. To change the name, under SSID, enter a new name between 2 and 32 characters and write it down somewhere safe.
  9. To hide the network from public discovery, disable Broadcast SSID.
  10. To limit how long a guest can be logged in, next to Time Stamp, tap the menu and select a duration.
  11. To require guests to sign in with a password:
    1. Next to Auth Option, tap the menu and select PasswordAuth.
    2. In Password, enter a new password between 8 and 63 text characters long. To view this password, tap the eye icon.
      Write down this password somewhere safe.
  12. When you are done changing your WiFi settings, click Save.
Last Updated:07/07/2025 | Article ID: 000060318
Our team is here to help!
Phone
Chat
Email
