To change your switch user interface to English:
- Connect your computer to the same network as the switch.
You can use a WiFi or wired network connection, or connect directly to a switch that is off-network using an Ethernet cable. - If you know your switch’s IP address, enter it in the address field of your web browser.
The login window opens.
If you do not know your switch’s IP address, you can use the NETGEAR Switch Discovery Tool to find your switch. - Enter the switch’s password in the password field.
The switch’s default password is password.
The Switch Information page displays. - In the upper right corner of the page, select English from the drop-down menu.
- Click YES in the dialog box to confirm that you want to change the user interface language.
The user interface changes to English.
