Router Link LED
This LED indicates the WiFi connection between the extender and the router.
- Solid white. Best connection.
- Solid amber. Good connection.
- Solid red. Poor connection.
- Off. No connection.
Client Link LED
- Solid white. The extender is connected to a WiFi-enabled computer or mobile device.
- Off. The extender is not connected to a WiFi-enabled computer or mobile device.
WPS LED
- Blinking white. A WPS connection is being established.
- Solid white. The extended network is enabled with WiFi security (either WPA or WPA2).
- Off. The extended network is enabled without WiFi security.
Ethernet LED
- Solid white. An Ethernet device is connected to an Ethernet port.
- Off. No Ethernet devices are connected to an Ethernet port.
Power LED
The Power LED is on the back of the extender.
- Solid green. The extender is powered on.
- Solid amber. The extender is booting.
- Blinking amber. The extender is resetting to its factory default settings.
- Blinking green. The firmware is corrupted.
- Off. The extender is powered off.
