Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Link aggregation (LAG) between two network devices allows your devices to treat multiple Ethernet links as if they were a single link to increase bandwidth or provide fault tolerance. For more information about link aggregation, see What are link aggregation and LACP and how can I use them in my network?
This article explains how to set up a static LAG between a Smart Managed Plus Switch and a QNAP NAS (QTS version 4.3.3.0209).
Note: Please refer to the datasheet of your Smart Managed Plus Switch to confirm that it supports static LAG.
Set up LAG on the Smart Managed Plus switch.
  1. Open a web browser on a computer that is connected to the same network as your switch or is connected to the switch directly through an Ethernet cable.
  2. Enter your switch’s IP address in the address bar of your web browser, or use a saved bookmark to access your switch.
  3. Enter your administrator password and press Enter.
    The default password is password.
    The home page displays.
  4. Select System - LAG - LAG Configuration.
  5. Select the checkbox beside the LAG that you want to set up.
    If LAG ID 1 is not already configured, select LAG ID 1.
  6. Set Admin Mode to Enable.
  7. Click Apply
  8. Select LAG Membership.
  9. In the LAG ID dropdown menu, choose the LAG ID that you configured in step 5.
  10. Click each port that you want to make a member of the LAG.
  11. Click Apply.
Set up LAG on the QNAP NAS.
  1. Log in to the admin page of your QNAP NAS.
  2. Select Control Panel - Network & File Services - Network & Virtual Switch.
  3. Select Port Trunking, then click Add.
  4. Click each port that you want to make a member of the LAG on the NAS.
  5. Check "Warn me if a network cable is disconnected from the trunking group".
  6. Click Next.
  7. Select Managed Switch.
  8. Click Next.
  9. Select Balance-xor.
  10. Click Apply.
Connect the ports that you made members of the LAG on the switch to the ports that are members of the LAG on the QNAP NAS.
Note: All ports that participate in a LAG (that is, the ports on both devices) must use the same port speed and duplex mode. It is recommended that the ports are configured for auto-negotiation.
Last Updated:07/07/2025 | Article ID: 000053557
Our team is here to help!
Phone
Chat
Email
