Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Link aggregation (LAG) between two network devices allows your devices to treat multiple Ethernet links as if they were a single link to increase bandwidth or provide fault tolerance. For more information about link aggregation, see What are link aggregation and LACP and how can I use them in my network?
This article explains how to set up link aggregation between a GS908E Smart Managed Plus Switch and a Synology NAS (DSM version 6.2-23511).
Set up LAG on the GS908E switch.
  1. Open a web browser on a computer that is connected to the same network as your switch or is connected to the switch directly through an Ethernet cable.
  2. Enter your switch’s IP address in the address bar of your web browser, or use a saved bookmark to access your switch.
  3. Enter your administrator password and press Enter.
    The default password is password.
    The home page displays.
  4. Select Switching - Link Aggregation.
  5. Click the slider beside LAG 1 or LAG 2 to enable the LAG that you want to set up.
    If LAG 1 is not already configured, choose LAG 1.
  6. Click each port that you want to make a member of the new LAG.
  7. Click Apply.
Set up LAG on the Synology NAS.
  1. Log in to the admin page of your Synology NAS.
  2. Select Control Panel - Connectivity - Network.
  3. Select Network Interface - Create - Create Bond.
  4. Select Balance XOR.
  5. Click Next.
  6. Click each port that you want to make a member of the LAG on the NAS.
  7. Click Next.
  8. Select whether to use a DHCP assigned or fixed IP address on the LAG.
  9. Click Apply.
Connect the ports that you made members of the LAG on the switch to the ports that are members of the LAG on the Synology NAS.
Note: All ports that participate in a LAG (that is, the ports on both devices) must use the same port speed and duplex mode. It is recommended that the ports are configured for auto-negotiation.
Last Updated:07/07/2025 | Article ID: 000053554
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
