Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Link aggregation (LAG) between two network devices allows your devices to treat multiple Ethernet links as if they were a single link to increase bandwidth or provide fault tolerance. For more information about link aggregation, see What are link aggregation and LACP and how can I use them in my network?
This article explains how to set up link aggregation between a GS810EMX Nighthawk Pro Gaming Switch and a Synology NAS (DSM version 6.2-23511).
Set up LAG on the GS810EMX switch.
  1. Open a web browser on a computer that is connected to the same network as your switch or is connected to the switch directly through an Ethernet cable.
  2. Enter your switch’s IP address in the address bar of your web browser, or use a saved bookmark to access your switch.
  3. Enter your administrator password and press Enter.
    The default password is password.
    The home page displays.
  4. Select Switching - LAG.
  5. Click LAG 1, LAG 2, LAG 3, or LAG 4 to select the LAG that you want to set up.
    If LAG 1 is not already configured, select LAG 1.
  6. Click each port that you want to make a member of the new LAG.
  7. Leave the Static/LACP slider set to on so that LACP is enabled.
  8. Click the Disable/Enable slider to turn on the LAG.
  9. Click Apply.
Set up LAG on the Synology NAS.
  1. Log in to the admin page of your Synology NAS.
  2. Select Control Panel - Connectivity - Network.
  3. Select Network Interface - Create - Create Bond.
  4. Select IEEE802.3ad Dynamic Link Aggregation.
  5. Click Next.
  6. Click each port that you want to make a member of the LAG on the NAS.
  7. Click Next.
  8. Select whether to use a DHCP assigned or fixed IP address on the LAG.
  9. Click Apply.
Connect the ports that you made members of the LAG on the switch to the ports that are members of the LAG on the Synology NAS.
Note: All ports that participate in a LAG (that is, the ports on both devices) must use the same port speed and duplex mode. It is recommended that the ports are configured for auto-negotiation.
Last Updated:07/07/2025 | Article ID: 000053552
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
