You must activate the port-based VLAN mode (also referred to as the basic VLAN mode) before you can add and manage port-based VLANs.
Click a topic from the following list to skip to that topic:
- Activate the Port-Based VLAN Mode
- Create a Port-Based VLAN
- Change a Port-Based VLAN
- Delete a Port-Based VLAN
By default, all types of VLANs are disabled on the switch. Before you can add and manage port-based VLANs, you must activate the port-based VLAN mode. This mode is also referred to as the basic VLAN mode.
When you activate the port-based VLAN mode, VLAN 1 is added to the switch and all ports (1 through 8) are members of VLAN 1. This is the default VLAN in the port-based VLAN mode.
To activate the port-based VLAN mode:
- Open a web browser from a computer that is connected to the same network as the switch or to the switch directly through an Ethernet cable.
- Enter the IP address that is assigned to the switch.
The login page opens. - Enter the switch password.
The default password is password. The password is case-sensitive.
The Home page displays. - From the menu at the top of the page, select SWITCHING.
The Quality of Service (QoS) page displays. - From the menu on the left, select VLAN.
The VLAN page displays. - In the Port-based VLAN (Basic Mode) section, click the ACTIVATE button.
A pop-up window opens, informing you that the current VLAN settings will be lost. - Click the OK button.
Your settings are saved and the pop-up window closes. By default, VLAN 1 is added.
A port-based VLAN configuration lets you assign ports on the switch to a VLAN. The number of VLANs is limited to the number of ports on the switch. In a basic port-based VLAN configuration, ports with the same VLAN ID are placed into the same VLAN. One port can be a member of multiple VLANs.
By default, all ports are members of VLAN 1.
To create a port-based VLAN:
The VLAN page displays. - In the Port-based VLAN section, click the ADD VLAN button.
- Specify the settings for the new VLAN:
- VLAN Name. Enter a name from 1 to 20 characters.
- VLAN ID. Enter a number from 1 to 8.
- Ports. Select the ports that you want to include in the VLAN through a combination of the following actions:
- Click the Select All link to add all ports to the VLAN
- Click the Remove All link to remove all selected ports from the VLAN.
- Click the icon for an unselected port to add the port to the VLAN.
- Click the icon for a selected port to remove the port from the VLAN.
The icon for a selected port displays blue.
If ports are members of the same LAG, you must assign them to the same VLAN.
- Click the APPLY button.
Your settings are saved. The new VLAN shows in the Port-based VLAN section.
You can change the settings for an existing port-based VLAN.
To change a port-based VLAN:
The VLAN page displays. - In the Port-based VLAN section, click the down arrow for the VLAN that you want to change.
- Click the EDIT button.
- Change the settings for the VLAN:
Your settings are saved. The modified VLAN shows in the Port-based VLAN section.
You can delete a port-based VLAN that you no longer need.You cannot delete the default VLAN.
If you deactivate the port-based VLAN mode, all port-based VLANs are deleted.
To delete a port-based VLAN:
The VLAN page displays. - In the Port-based VLAN section, click the down arrow for the VLAN that you want to delete.
- Click the DELETE button.
Your settings are saved. The VLAN is deleted.
For more information about using VLANs with your GS908E switch, see the following knowledge base articles:
- What types of VLANs can I create on my NETGEAR GS908E switch?
- How do I create and manage 802.1Q VLANs on my NETGEAR GS908E switch?
