Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Daisy chain is enabled by default on your Orbi WiFi System.
To disable daisy chain topology:
  1. Launch a web browser from a computer or mobile device that is connected to your Orbi network.
  2. Enter http://orbilogin.com.
    A login window displays.
  3. Enter the user name and password.
    The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
    The BASIC Home page displays.
  4. Select ADVANCED > Wireless Settings.
  5. Clear the Enable Daisy-Chain Topology check box.
  6. Click the APPLY button.
    Your settings are saved.
Last Updated:07/07/2025 | Article ID: 000048460
Our team is here to help!
Phone
Chat
Email
