The amount of power that your Orbi devices use varies depending on the state that they’re in and the combination of your Orbi devices. To calculate how much power your Orbi system is using, add the watts based on the state that each of your devices is in. For example, if you have an Orbi Pro router and satellite(SRK60) and an Orbi Pro add-on satellite(SRS60) that are idle, your Orbi Pro WiFi system is using 18.3 Watts.
The following table lists the amount of power Orbi models use in various states.
Product |
Off |
Idle |
On |
Full load |
Orbi Pro router |
0.083W |
6.1W |
10.5W |
22.32W |
Orbi Pro satellite |
0.083W |
6.1W |
10.5W |
22.32W |
Orbi Pro add-on satellite |
0.083W |
6.1W |
10.5W |
22.32W |
