The sync process for your Orbi Pro satellite depends on whether your satellite came with your Orbi Pro WiFi System (SRK60) or if your satellite is an add-on satellite (SRS60).
If you need instructions for syncing an add-on Orbi Pro satellite (sold separately), visit How do I sync an add-on satellite with my Orbi Pro router?.
The Orbi Pro WiFi System includes an Orbi Pro router and an Orbi Pro satellite. The Orbi Pro satellite in the WiFi system is preset to automatically find and sync to your Orbi Pro router.
To sync your Orbi Pro satellite that came in the box with your Orbi Pro router:
- Place your satellite.
For more information, visit Where should I place my Orbi Pro devices? - Connect the satellite to a power source.
- If the Power LED on the back of the satellite doesn’t light, press the Power On/Off button.
The satellite ring LED pulses white. The satellite automatically finds the Orbi router’s WiFi signal and attempts to sync to the Orbi Pro router.
The satellite ring LED lights one of the following colors for about three minutes then turns off:- Blue. The Orbi router and satellite successfully synced, and the connection between the router and satellite is good.
- Amber. The Orbi router and satellite successfully synced, and the connection between the router and satellite is fair. Consider moving the Orbi satellite closer to the Orbi router.
- Magenta. The Orbi router and satellite failed to sync. See Step 4.
- If the satellite ring LED is magenta, move the satellite closer to the router then sync the satellite to the router:
- Press the Sync button on the back of the router.
- Within two minutes, press the Sync button on the back of the satellite.
