Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
The following instructions require a drop ceiling.
To mount your Orbi Pro devices using the ceiling mount:
  1. Place your Orbi router or satellite on the mount base and attach the router or satellite to the base with the provided screws.
  2. Attach the mount cover to the mount base.
  3. Attach the T-bracket to the ceiling bracket using the T-bracket screws.
  4. Loosen the screw so that the locking plate can slide.
  5. Secure the T-bracket to the T-bar and tighten the screw.
  6. Slide the mount base into the ceiling bracket.
    Your Orbi router or satellite is mounted to the ceiling.
Last Updated:07/07/2025 | Article ID: 000045857
Our team is here to help!
Phone
Chat
Email
