To mount your Orbi Pro devices using the wall mount:
- Place your Orbi router or satellite on the mount base and attach the router or satellite to the base with the provided screws.
- Attach the mount cover to the mount base.
- Use the wall anchors with screws to attach the wall bracket to the wall.
- Slide the mount base onto the wall bracket.
Your Orbi Pro devices are mounted.
Last Updated:07/07/2025
Article ID: 000045856
