Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
To enable or disable the Smart Connect feature:
  1. Launch a web browser from a computer or mobile device that is connected to your extender’s network.
  2. Log in to your extender:
  3. Enter your admin email address and password and click the LOG IN button.
    The Status page displays.
  4. Select Settings > Wireless.
    The Wireless page displays.
  5. To enable the Smart Connect feature, select the Yes radio button.
    Note: To use this feature, the 2.4 GHz and 5 GHz networks must use the same SSID and password.
  6. To disable the Smart Connect feature, select the No radio button.
    If you disable this feature, you can set a new SSID and password for the extender’s 2.4 GHz and 5 GHz networks in the Network Name (SSID) and WiFi Password fields on this page.
  7. Click the SAVE button.
    Your settings are saved.
Last Updated:07/07/2025 | Article ID: 000044734
Our team is here to help!
Phone
Chat
Email
