Bug Fixes:
- Fixed HTTPS scanning issue: when visiting HTTPS website the following error occurs: “The SSL connection cannot be established - REASON: the security certificate was issued by a company you have not chosen to trust”.
- Fixed the issue of getting invalid certificate | ERR_CERT_INVALID | OS X).
- Fixed the AD settings lost after re-login.
- Fixed the issue where the download ISO is not possible when HTTP scanning is enabled.
- Fixed the issue where the IPSec tunnel is formed, but traffic cannot be passed through client-to-box ipsec vpn, when using SHA2-256 or SHA2-512 integrity algorithm in vpn policy or mode config record.
- Fixed the special character "¤" issue where the pre-shared key is allowed.
Known Issues and Limitations:
- Invalid MTU on WAN interface shouldn't be allowed.
- Maximum characters in fully qualified domain entry was not getting deleted.
- Guest is able to establish/drop the IPSec VPN tunnel.
- Guest user was able to perform operations in wan status page.
- Help page need to be updated in Policies page for "Related Policies Table".
- Guest is able to change the password after login from default portal link.
- Username with special characters cannot be deleted.
- Guest user not logging out after admin changes guest password.
- "Deny Login from WAN interface" option is unchecked for custom guest user in login policies page.
- DUT is not broadcasting its connected VLAN interface routes.
- Able to add two routes for the same destination with two different gateways in Load Balancing.
- Unable to access the security page and it shows white page after deleting secondary IP address if it is associated with firewall rule.
- Unable to run Inbound traffic with service as ANY, if we add outbound rule with down interface with ANY service.
- Client tunnel is getting dropped after 5 to 10 minutes.
- Device is not accessible after long duration stability test.
Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
Download Links:
UTM5 / 10 /25: http://www.downloads.netgear.com/files/GDC/UTM10/UTM5_10_25-Firmware-V3.6.2-8.zip
UTM50: http://www.downloads.netgear.com/files/GDC/UTM50/UTM50-Firmware-V3.6.2-8.zip
UTM150: http://www.downloads.netgear.com/files/GDC/UTM150/UTM150-Firmware-V3.6.2-8.zip
